Paver Patio Edging - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 11:13 AM   #1
Rewards Points: 142
paver patio edging
i am planning my new paver patio. the pavers, i expect they need something to keep the end pieces in place. i am asking for options, and if you know of a product that is good or bad.
thaanx.
Fix'n it is offline   Reply With Quote
Old 03-31-2014, 11:10 AM   #2
r0ckstarr's Avatar
Rewards Points: 1,978
Your post reminded me of this video. The edge pieces are at 5:55.
r0ckstarr is online now   Reply With Quote
Old 03-31-2014, 03:21 PM   #3
Uni-decor paves as shown in those pavors will work. You can also use standard 4"x8" pavers. For ease of installation that is what I would use if you are not experienced or do not have a saw to cut the pavers.
Altered Grounds Landscaping
mbender2004 is offline   Reply With Quote
Old 03-31-2014, 07:21 PM   #4
concretemasonry's Avatar
Rewards Points: 2,570
For any real paver installation, you need an edge restraining to prevent lateral movement, separation and loss of strength. Common edge restraints are flexible plastic, aluminum and steel that can be set at any height as long as the have enough embedment in the soil to be stable. Often spikes work, but a buried concrete curb might work depending on the situation.
Dick
concretemasonry is offline   Reply With Quote
Old 04-01-2014, 08:56 PM   #5
Rewards Points: 142
thanx. i am, so far, going to use the pavers that are already down. i am going to move that patio out about 4-5'. and raise the side towards the house, for drainage. the side by the yard will be about grade height. but the house side, i have to raise that 8-12" (haven't figured that out yet). and i have yet to figure out the edge restaint for the house side.
Old 04-01-2014, 09:24 PM   #6
Rewards Points: 142
this is where i am at now. the closer boards are going to be, about, the pavers. i also need to figure out how to build this small retaining wall. the is already base and sand down.
Old 04-04-2014, 04:48 AM   #7
Rewards Points: 324
I recently put down paving myself. I set pavers in concrete for the edge, much the same as these guys do: http://www.pavingexpert.com/edging1.htm
There's a goldmine of useful info on that site :-)
mgp roofing is offline   Reply With Quote
The Following User Says Thank You to mgp roofing For This Useful Post:
r0ckstarr (04-04-2014)
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 06:20 AM
Building a paver patio, questions about process and design NewHomeDIYGuy Landscaping & Lawn Care 11 03-30-2013 08:25 AM
Is PVC too brittle in cold for drain under a paver patio? BrandonC_1972 Landscaping & Lawn Care 1 07-20-2012 01:18 AM
12-18" Spacing Between Foundation And Paver Patio Bad Idea? ErikU19 Landscaping & Lawn Care 3 04-09-2011 09:20 AM
Paver Patio question Hoopscoach Landscaping & Lawn Care 1 04-25-2010 04:55 PM
