Paver Patio Base Material - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 11:58 AM   #1
I'm putting in a 15' x 10' stone paver patio. I called the local quarry and they suggested using "Class i sand" as the 5 inch base with another 1 inch of depth of the polymeric sand on top of it.
They said the "class i" has a relative consistency of kitty litter and is real dusty. Does this sound good or bad?
fpr4 is offline   Reply With Quote
Old 06-17-2009, 04:10 PM   #2
la15ota's Avatar
I'm not sure where you're from but the usual recommendation is to put done 4" to 6" of base rock (compacted) and then a 1" layer of washed Concrete sand, lay the stone/pavers and finally sweep in the polymeric sand and pass a vibrating plate over to lock everything together.
Polymeric sand is expensive and used to lock the stones/pavers together not as the 1" sand layer.
la15ota is offline   Reply With Quote
Old 06-17-2009, 08:26 PM   #3
Remodeling Contractor
that about says it.
Paver Base 7echo Landscaping & Lawn Care 4 08-25-2008 12:51 PM
edging material for base rock and patio pavers la15ota Landscaping & Lawn Care 1 07-04-2008 10:01 AM
new deck or paver patio meth Landscaping & Lawn Care 7 06-06-2008 05:20 PM
Paver Patio Prep, base amounts bartic Landscaping & Lawn Care 4 05-29-2008 09:01 AM
