Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-26-2008, 05:29 PM   #1
diy'er
la15ota's Avatar
Paver Patio
Planning to do a paver patio.
Our yard is tiny, probably no more then 20 ft from the back door to the rear fence, so drainage is key. We will be sloping the patio away from the house.
I was wondering if it would be over kill to add French drains around the perimeter of the house foundation and at the end of the patio and have them link up with the drains already installed in the ground to take the rain water away from the gutters.
la15ota is offline   Reply With Quote
Old 03-02-2008, 01:53 PM   #2
Paver Patio
if your not changing the existing grade thats there now and your not currently having any drainage issues I wouldn't see the need to add the french drains
rocklyr is offline   Reply With Quote
Old 03-02-2008, 07:15 PM   #3
Master General ReEngineer
Bondo's Avatar
Paver Patio
Ayuh,....
The paved surface, when pitched will shed the water better,+ quicker than a rough grade......
I'd be more concerned about where the water ends up at the bottom of the pitch,....
Does that area drain well,..??
Old 03-03-2008, 02:49 PM   #4
diy'er
la15ota's Avatar
Paver Patio
Hi Bondo,
The ground already has some drainage pipes installed and right now the water drains away from the house and into those spots without any pooling near the home.
Old 03-04-2008, 03:07 PM   #5
Bondo's Avatar
Paver Patio
Ayuh,....
In that case,... Yor pavers should shed the water to the exact same place,....
No Problem......
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Help me to install a paver patio 707782 Landscaping & Lawn Care 5 09-28-2007 08:42 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
