Paver Help Needed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2010, 04:56 PM   #1
Paver help needed
I have a question about laying concrete pavers. Should I leave a gap between them or just butt them against each other. The patio is a 17 ft circle with a center firepit and a wall/bench on half of the perimiter. I am conserned about freeze/thaw (Chicago area) putting presure on the surrounding structures as the pavers are traped by them. If I need to gap them then how much.
jkon51 is offline   Reply With Quote
Old 07-09-2010, 05:01 PM   #2
Ours (in Chicago as well) is laid with the bricks right up against each other and it just naturally spreads a little so you shouldn't have a problem with the cold. In fact, we get some moss in between, so the spacing is almost a pain at time.
Allison1888 is offline   Reply With Quote
Old 07-09-2010, 06:13 PM   #3
Concrete & Masonry
Rewards Points: 526
Unless the pavers are perfectly manufactured, you will need some kind of gap. The fat that you have the option not to gap them tells me you have clay pavers??
jomama45 is offline   Reply With Quote
Old 07-09-2010, 07:57 PM   #4
I placed my concrete pavers right up tight as possible to each other to here in Toronto - similar cold as Chicago - ok so far.
Charlie123 is offline   Reply With Quote
Old 07-11-2010, 10:18 PM   #5
Paver help needed
Always use a click and drop method when installing pavers. The vast majority of pavers have spacer bars on them, which provides spacing between the pavers. I to, am from the Chicago area, and this is my profession. If you need additional info on paver installation, I have published several articles on step by step instructions for paver installation. Here's a link for brick paver installation. http://www.goarticles.com/cgi-bin/showa.cgi?C=3087709
There is also a complete series of articles from, soils, base material, bedding material, install and final compaction. Hope this helps. Let me know if you need any other questions answered.
Kurtzilla is offline   Reply With Quote
cutting paver stone hi09 Building & Construction 2 04-25-2010 07:24 AM
quick help needed regarding paver patio base vetting Landscaping & Lawn Care 2 04-21-2010 05:01 PM
Brick paver help needed jkon51 Landscaping & Lawn Care 5 04-16-2010 06:09 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 09:22 PM
Paver install-hand tamper vs plate compactor bigboyjoel Landscaping & Lawn Care 9 07-23-2008 03:48 PM
