Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-13-2012, 09:29 PM   #1
Paver base compaction amount?
Does anyone know how much crushed concrete or crushed rock for a brick paver base will compact after running over it with a plate compactor every 2"? I'm shooting for 6" after compaction. I've seen people say it won't compact much and others say 25%. I'm planning on 1/4" minus crushed concrete.
soasquad is offline   Reply With Quote
Old 09-14-2012, 01:26 PM   #2
AGWhitehouse's Avatar
There are many factors...
For stone dust, I've typically experienced about 1"-1.5"+/- compaction on a 6-8" loose stone bed...meaning, you wheelbarrow/tractor in 7"+/- of stone and it will generally compact to about 6"+/-.
The factors are the size of the media, the wetness, and the amount of compaction prior to the plate whacker (ex. walking on it, etc.).
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-14-2012, 02:46 PM   #3
Civil Engineer
If you are using 1/2 inch to 3/4 inch angular crushed stone or crushed concrete, you will typically not get much more than 10% compaction by volume no matter how hard you tamp. Sometimes you appear to get more, however this may be due to compaction of the underlying soil. Loose soil can often be compacted 30%, occasionally more, but not crushed stone or concrete.
Keeping job site clean while loading in base for paver patio BrandonC_1972 Landscaping & Lawn Care 1 07-29-2012 12:59 AM
Using Concrete as Paver Base? Boiler98 Landscaping & Lawn Care 4 07-27-2012 11:09 AM
Paver Base ... pea gravel depth? jmclear Landscaping & Lawn Care 4 07-11-2011 05:36 PM
Compaction of base material for paver patio Ibbotson Building & Construction 1 07-06-2011 06:18 PM
How much will road base compact? jbdkisner Landscaping & Lawn Care 2 02-04-2010 07:10 PM
