Patio sub structure and lavel
Hi Guys,
I'm planning several interlocking patios. The first will be about 250 square feet and L shaped. My soil is clay and I will put down 6+ inches of compacted gravel/sand mix.
Question:
Should/can I put down a level layer of gravel/sand mix and compact followed by a 1-1/2" layer of concrete sand. Should I level the substrate for draining or will it be OK to grade the top sand layer?
How is this normallly done? When do you grade for water flow?
Thanks.
