Patio Root Repair - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-17-2013, 03:19 PM   #1
Rewards Points: 306
Patio root repair
I have a patio that is paved in red brick. The bricks are mortared together in 4ft x 4ft squares separated by 2x4 framing. The problem is a couple of these squares have lifted up a bit due to roots pushing underneath. The mortar is all intact still. If possible, I would like to lift each of these squares, trim the roots, level the sand and replace the square so it sits at the proper level again.
I was thinking of using a large tripod and come-along winch to lift each square. I could remove the wood framing around each one, or even drill and attach some anchors to the brick surface. I don't know if this is possible without breaking the mortar joints, since 4' x 4' brick is a lot of weight.
Thoughts?
tns1 is offline   Reply With Quote
Old 07-17-2013, 03:26 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
The mortar may look intact, but there probably many small or microscopic cracks the will increase one there is no support from below.
It will be better to tear it out, replace what bricks are salvageable and correct/minimize the root problem before rebuilding if you like the look.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
joecaption (07-17-2013)
Building a new patio cover without footers MStarr Building & Construction 8 01-31-2013 09:06 AM
deck over top of concrete patio mommywoman Concrete, Stone & Masonry 1 08-30-2012 01:11 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Patio Chair Repair shumakerscott General DIY Discussions 6 07-21-2010 03:15 PM
Attaching a deck to the patio DAdams982 Building & Construction 12 07-12-2010 10:50 AM
