-   -   Patio root repair (http://www.diychatroom.com/f16/patio-root-repair-183752/)
tns1 07-17-2013 03:19 PM
Patio root repair
I have a patio that is paved in red brick. The bricks are mortared together in 4ft x 4ft squares separated by 2x4 framing. The problem is a couple of these squares have lifted up a bit due to roots pushing underneath. The mortar is all intact still. If possible, I would like to lift each of these squares, trim the roots, level the sand and replace the square so it sits at the proper level again.
I was thinking of using a large tripod and come-along winch to lift each square. I could remove the wood framing around each one, or even drill and attach some anchors to the brick surface. I don't know if this is possible without breaking the mortar joints, since 4' x 4' brick is a lot of weight.
Thoughts?
concretemasonry 07-17-2013 03:26 PM
The mortar may look intact, but there probably many small or microscopic cracks the will increase one there is no support from below.
It will be better to tear it out, replace what bricks are salvageable and correct/minimize the root problem before rebuilding if you like the look.
Dick
