Patio Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 08:32 AM   #1
patio question
hi, i'm planning a 28X18 patio that will be under an elevated deck. is there any downside to doing a concrete paver paver with pea gravel grout lines, similar to the attached pic.
http://ecyprex.com/images/photo-9.jpg
i plan to edge the patio with 4x4 treated lumber. the base with be 3" of crushed gravel and about 1 or 1.5" of sand. will i have any issues with the pavers moving? will i regret using pea gravel because it makes a mess everywhere?
ryan319 is offline   Reply With Quote
Old 04-18-2010, 05:16 PM   #2
The pea stone will be all over the place. If your looking for a grout line look then try a different color paver. I would not use pea stone with pavers. Your pavers will move all over because the peastone will not hold them in place. Where are you located? I would go with a thicker crushed gravel base in the north because of frost/freeze
Bushman is offline   Reply With Quote
Old 04-18-2010, 07:29 PM   #3
i'm also in the north (PA). i think i'm just going to do a solid patio.
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
patio cover/roof footing question toolbeltmamma Building & Construction 20 02-24-2012 01:10 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New Paver Patio Installation ddave23 Landscaping & Lawn Care 3 07-14-2008 10:03 AM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
