-   -   Patio - cement foundation vs gravel/traffic bond... (http://www.diychatroom.com/f16/patio-cement-foundation-vs-gravel-traffic-bond-137906/)
NewHouseMM 03-22-2012 08:05 PM
We've built a new house in southern Wisconsin (north of Milwaukee). It is in an area with clay. We are trying to decide on a patio foundation. We are concerned about settling and upkeep in the long run.
Which would be better:
1) have a cement patio poured (with decorative pavers installed on the top) OR
2) create an 18 inch foundation of gravel, traffic bond, sand, etc.
Which would be a better foundation for the pavers, brick, or blue stone?
concretemasonry 03-22-2012 09:34 PM
If you are just putting in a patio and considering interlocking concrete pavers (up to 10" maximum horizontal dimension), you probably need about 6" of compacted road base over the caly with the top sloped for drainage and and uniform 1" thick setting bed of clean, uncompacted concrete sand. Set the pavers tightly, sprinkle fine sand an compact with a plate vibrator to even the surface and create the structural interlock - common method used internationally.
For concrete a compacted similar base id adequate and make sure you have control joints to control/hide cracks, depending on the size.
For Bluestone, I cannot offer much because of the limited exposure for a small use variable product by comparison.
You have several producers of interlocking concrete pavers (60mm, 80mm thicknesses) with different shapes in your area and they are also available in the big boxes (at least the 60mm) in many different shapes for use in different patterns. Specialized suppliers will have more options.
Dick
