Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 12:53 PM   #1
patio
we would like to build a hardscape patio over a section of our septic drain line it will just pavers placed over the top where the grass is. can we do this if not how far do we have to be from the drain line
crosscru5 is offline   Reply With Quote
Old 07-14-2010, 05:30 PM   #2
crosscru5, a couple of questions for you. How old is your septic system and the lines? If it's fairly old then I would recommend using caution over the lines, as not to bust or colapse the line. If it is an older system, then it might also be to your advantage to have your lines Hydro Lifted to clean the lines of any solids that may have filtered through. Best to check with your local septic company.
Newer system will tolerate a little more point loading of weight over the system. Depending on what region your in, you might be able to minimize the amount of excavation needed for properly basing up your project. For additoinal info on properly basing up your patio / paver project, go to this link. http://www.goarticles.com/cgi-bin/showa.cgi?C=3087674 Goodluck
Kurtzilla is offline   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
