Patching Holes In Asphalt Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 07:18 PM   #1
Patching holes in asphalt driveway
Has anybody used motar to patch holes in an asphalt driveway? I had planned on using a trowel to apply the motar, then adding gravel on the top surface to match the existing asphalt. When all is dry coating the driveway with a quality asphalt sealer. Comments please.
joe3534 is offline   Reply With Quote
Old 11-20-2009, 07:49 PM   #2
Remodeling Contractor
expands and contracts at different rates... the concrete will crack and fall out in no time. asphalt is more flexible. And the concrete requires a better base material for it to last.
Old 11-21-2009, 08:55 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... It'll be tempory at best....
Compacted Cold Patch will work slightly better, but Hot asphalt is Best...
Bondo is online now   Reply With Quote
Old 11-22-2009, 08:29 AM   #4
Motar Patch
I forgot to mention that I live in South Florida. We do not get frosts here and the temperature very rarely goes below 50 degrees.
Old 11-22-2009, 10:01 AM   #5
Bondo's Avatar
Rewards Points: 334
Ayuh,... Same answer, but it might last slightly longer...
Old 11-22-2009, 10:16 AM   #6
Still apples and oranges.. and you have oranges in FL.... Use asphalt patch.. easier and cheaper and will work longer and look better.
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 03:30 AM
Asphalt driveway tripower Building & Construction 1 12-31-2008 02:19 PM
Suggestions for patching holes in fridge door? iris@sonic.net Appliances 3 09-07-2008 08:40 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
asphalt grindings driveway DIY? johnny331 Landscaping & Lawn Care 2 09-28-2007 05:37 AM
