Part Identification - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 07:24 PM   #1
Part Identification
LAWNBOY MOWER PART
Please, I need to identify exactly this part, in order to be able to order it from a supplier.
I believe it is a little metal key that holds the gear on a shaft, of a Comercial Lawnboy self propelled mower. There are to of these keys on the gear system. Of is right, and the other one is left. Meaning the pointed part is oriented either left or right.
I hope. I am not confusing everybody with my explanation.
Your assistance with this request is greatly appreciated.
I am attaching a photo of the mentioned “key”.
tomoni82 is offline   Reply With Quote
Old 07-22-2010, 06:36 AM   #2
47_47's Avatar
Rewards Points: 50
Originally Posted by tomoni82 View Post
LAWNBOY MOWER PART
Well you confused me . There are a few different types of 'keys' to spline a gear to a shaft. Parallel (square), woodruff (half moon) and tapered. The only one that I have seen with a tab is a tapered key.
47_47 is offline   Reply With Quote
Old 07-22-2010, 07:04 AM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Hard to tell from the pict. is it broken/bent or is it supposed to loo that way? it almost looks like some kind of pawl, made to keep something (gear or flywheel?) from turning in the wrong direction.
Go here https://lookup3.toro.com/partdex/ind...Caller=lawnboy
enter the model # and see if you can find it. if not just take it and your model/serial info to your local Lawn Boy dealer or small engine shop
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-22-2010, 09:44 AM   #4
Part Identification
Thanks guys for your prompt response. That is the whole key,it is not broken.
Two of those keys fits on each side of a gear on a shaft that holds the self propelled tire. I am going to take it to a Lawnboy repair center,and ask them to help me out. The Lawnmower is about 10 years old and Lawnboy does not carry parts for that model anymore. I will try eBay to see,if somebody might have something like that.
Thanks again!
Old 07-25-2010, 02:36 PM   #5
Part identification
I have more information on the subject part!
IT IS A ROCKING KEY
Steel
Forged
Rocks in the drive shaft and drive shaft gear to lock the key in places so the gears begin to turn. Then when the mower is pulled in reverse it rocks the other way and disengages the gears.
It is number 14 in the attached drawing!
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 12:42 PM
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 06:43 PM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
How to get a level floor out of one that's part concrete and part wood Songbird Flooring 5 01-22-2009 11:24 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
