Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-16-2010, 10:58 PM   #1
-db
Painting a rusty chain link fence?
Some of the sections of the fence at a house we just purchased is fully covered in surface rust and I would like to paint the fence and would like some input on how to do it.
I'm thinking some of that rust converting primer, then would I be better off trying to spray paint or use a roller? Spraying will obviously be easier, but will waste alot of paint. But, if I rolled it on, will I end up with missed areas on the "inside" of the links and I'll have to paint the top bar with a brush?
I'm hoping this will work and not just rust through in a year.
-db is offline   Reply With Quote
Old 05-17-2010, 05:08 PM   #2
Don't know it all, yet!
Personally, I have had very good results with the rust converters. For painting a fence use a cheap brush. You can work the paint into all those little nooks. Spraying would be a big waste of paint. Don't go too fast or you will have it all over you.
If you are going with the original metallic finish, there is a galvanized paint made for fences.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 05-17-2010, 09:21 PM   #3
-db
Thanks for the input.
I was at Menards tonight and picked up 2 8oz bottles of Rustoleums Rust Reformer and a gallon of Rustoleums oil based chain link fence paint. The can doesn't say anything about being a galvanized paint.
I did use a can of the galvanized spray paint last fall on a section, but did not use the rust converter first, I just sprayed over the rust. It is showing some rust through already, so hopefully this will turn out better.
I also pick up a box of chip brushes from Harbor Freight.
Old 05-17-2010, 09:58 PM   #4
Tom Struble's Avatar
i would use a roller with say a 1/2'' nap
Tom Struble is offline   Reply With Quote
Old 05-17-2010, 10:08 PM   #5
-db
Have you tried this?
The paint can says use 1-1/2" nap, but the only one Menards has was $6.00 ea. I plan to look at Lowes when I'm there tomorrow (I bought the brushes for another project anyway).
weed wacking around a chain link fence reds_21 Landscaping & Lawn Care 23 07-30-2012 05:09 PM
gate for chain link fence dppatt Landscaping & Lawn Care 6 10-14-2009 07:17 PM
Non-Dirt/Concrete Base for Chain Link Fence Post suncowiam Building & Construction 7 06-04-2009 01:56 PM
Painting Chain Link Fence Canvas Thorusc General Discussion 5 08-18-2008 07:34 AM
Chain Link Fence Privacy? the question General Discussion 2 06-15-2008 11:08 AM
