Painted Patio? Removal Possible? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 07:22 PM   #1
Painted patio? Removal possible?
The builder of our home painted/sealed, not sure what used, but see pic below.
How can I get this removed and get down to the bare concrete so I can get the concrete look?
Tenacious--M is offline   Reply With Quote
Old 06-16-2009, 07:40 PM   #2
Sand blasting
Chemicals will take off the top layer
But the paint will absorb into the concrete
Not sure how succesful you will be
Old 06-17-2009, 10:38 PM   #3
Thanks SD!
Can you recommend a good cleaner that could help take the paint off. I was then thinking about a high psi pressure washer to remove....
Old 06-27-2009, 03:26 PM   #4
I was able to get the paint off using some Jasco Paint and Epoxy remover. Brushed it on with a broom and pressure washed off. Wasnt fun, but worked, eventually...
So here is what I have to work with now. These stains were underlying and I cant get them off. Is there somethign that can be used to remove these stains? The 3,500 psi pressure washer didnt even touch it...
.... I want to stain it a better color and put a nice protectoant over the top of that to give it a stone/granite look.
How can I do this? Can anybody walk me through it?
Old 06-27-2009, 04:34 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Big Problem
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-27-2009, 04:56 PM   #6
Originally Posted by PaliBob View Post
Big Problem
Im not following... can you explain?
Old 06-27-2009, 07:13 PM   #7
Tool Geek
PaliBob's Avatar
Don't you see the Monster?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-28-2009, 07:05 AM   #8
Concrete & Masonry
Rewards Points: 616
Belive it or not, If you plan on acid staining the patio, those spots should actually blend in just fine. They may actually add more intersest to the slab.
jomama45 is online now   Reply With Quote
Old 06-28-2009, 07:21 AM   #9
Rewards Points: 1,016
I was thinking the same - since the stains are so deeply into the concrete, best to try and work with them.
Old 06-28-2009, 09:32 PM   #10
Thanks! Thats good to know.
So what would be my next step to acid stain it? Im looking for a darker grey type color....
Old 06-28-2009, 10:28 PM   #11
Concrete & Masonry
Rewards Points: 616
Find a concrete supply yard that carries acid stain in your area & see if they will sell it to you as a HO. Some may not, as it is intended for professional use only. The only problem with acid staining in your situation is the color pallette is mostly reserved to tans & browns.
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
removal of 4x4's in patio concrete Mustanger151 Building & Construction 2 05-12-2009 06:55 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
Aluminum patio door removal yeterp Remodeling 2 11-08-2005 11:49 PM
