P.V.C GLUE Doesn't Hold - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 12:05 AM   #1
P.V.C GLUE doesn't hold
i had A te brake in my back yard its two in pipe so i replaced it and now my glew wont hold i turn on the presure and it blows i sanded the arias a lil and used primer
lonny is offline   Reply With Quote
Old 08-04-2011, 08:14 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
P.V.C GLEW doesnt hold
Okay, so the rules say I can't have any fun with this one? That's too bad!
Damn you Red Barron!!!
XXX
Old 08-04-2011, 09:29 AM   #3
the Musigician
DangerMouse's Avatar
Bud: As much as we may agree....
Lonnie: You REALLY need to spell check and edit your grammar and punctuation so we can understand your question.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Bud Cline (08-04-2011)
Old 08-04-2011, 09:32 AM   #4
Rewards Points: 150
What kid of glue did you use and how long did you wait to turn on the water?
Broughton is offline   Reply With Quote
Old 08-04-2011, 09:51 AM   #5
you think thats hard, you should come here and try to speak bacon holler
The older I get the better I was
Old 08-04-2011, 09:52 AM   #6
fabrk8r
fabrk8r's Avatar
A picture is worth a thousand misspelled words.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-04-2011, 10:58 AM   #7
Rewards Points: 3,130
My guess is that you're using the wrong glue. Each type of plastic pipe has its own special kind. Some are used with primer; some aren't. With the right glue, properly applied, you couldn't take the joint apart if you wanted to.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (08-04-2011)
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 02:16 AM
Installing glue down engineered floor brad4499 Flooring 6 03-12-2008 09:54 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
