Overseeding ?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-22-2006, 07:50 PM   #1
Overseeding ??
Greetings--
Yard at this property has a decent stand of St Augustine in most areas. THere are however several large areas that have nothing but dirt left-- due to dog runs, car parking and an old above ground pool.
I"d like to 1) make the lawn look better *quickly* and 2) get the St Augustine to grow and cover the bare areas.
The house is on the coast in Texas.
What should I use to overseed for the winter/spring ? How does one go about "planting" the seeds-- rake up the ground some first or ??
Piney is offline   Reply With Quote
Old 11-13-2006, 10:58 PM   #2
VHI
Hello Piney,
Overseeding is not going to get you grass quickly. I would suggest rye grass for quick winter grass then aerating before you over seed.
VHI is offline   Reply With Quote
Old 11-16-2006, 09:28 PM   #3
HarryHarley
HarryHarley's Avatar
Are the dog, cars and pool gone? The only fast way is sod. Otherwise, as stated rake hard and use rye. It will take rye 2-4 weeks to look decent. It will die off in spring.
ST Aug will spread good next summer. Make sure to fertilize Good luck.
What should I use to overseed for the winter/spring ? How does one go about "planting" the seeds-- rake up the ground some first or ??[/quote]
HarryHarley is offline   Reply With Quote
