Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-07-2007, 07:58 AM   #1
Mechanical Engineer
Question
Over fertilized - how to fix?
I was helping my girlfriend with her lawn one night and the drop spreader had gotten some moisture in it so the fertilizer was clogging up at the opening on the bottom. I adjusted the drop settings to let more fertilizer come out, but I opened it up too much. Her son ran the spreader over the lawn and he put too much down. Not his fault, mine for adjusting it too high.
How can I neutralize the fertilizer that we put down? Or can I? It's starting to kill the lawn in a couple of spots, and there are some streaks in the lawn where the grass is starting to turn brown. Is there anything I can do to prevent this from getting any worse? Or do I just have to let it run it's course, and put new seed down when the fertilizer has dissipated after a few rains?
gshock is offline   Reply With Quote
Old 08-07-2007, 10:09 AM   #2
You have to keep watering it.....really soak it as much as possible. If you already see brown spots, there will definately be more coming. I burned two areas in my lawn last year using Weed & Feed. Now I just use Scotts because it wont hurt the lawn.
Let it run it's course. You can reseed in a month, then you'll have a nice lawn in the spring.
Jeekinz is offline   Reply With Quote
Old 08-07-2007, 10:31 AM   #3
gshock---- Jeekinz is on the money. Try to flush the area with water as soon as possible. Really soak it. This will help dilute the fertilizer. It is also necessary to water the lawn very thouroughly after applying fertilizer to get the chemicals watered in and diluted so they don't have a chance to cause harm. Also, as Jeekinz said, look for a brand that says "Will not harm/burn lawn" on the label. Once the grass turns brown, the damage is already done. You will just need to let t run its coursse. This is commonly referred to as burning. don't feel bad....it is very easy to do and everyone does it until you get the hang of it.
I would recommend to set your spreader according to the instructions on the bag of fertilizer. It is also a good idea to match your spreader to your fertilizer...for example, Scotts spreader with Scotts fertilizer. Also, never leave any fertilizer in the spreader between uses. Any humidty or moisture will start to dissolve the fertilizer and clog the openings....not good! Hose it out and let it air dry between uses.
DIY4EVER is offline   Reply With Quote
Old 08-07-2007, 10:49 AM   #4
Mechanical Engineer
Talking
Thanks for the tips. It rained the next day after the fertilizer was put down. Hopefully, the damage won't be too bad. But I have a TON of seed that I can use to reseed the lawn. I think she does have a Scott's spreader, and Scott's fertilizer. She told me that what she got was part of a 4-step plan to kill the weeds and crab-grass, but she calls everything fertilizer. So I didn't realize that this was "fertilizer." I thought it was like Scott's turfbuilder, or something similar.
I'll let it sit for a few more weeks, then I'll reseed and water the crap out of it.
Thanks again, Fellas.
Old 08-07-2007, 02:16 PM   #5
Some or all bags of seed have a "use by date". Check and see what you got.
rjordan392 is offline   Reply With Quote
Old 08-07-2007, 02:30 PM   #6
Mechanical Engineer
I didn't realize that. I have some stuff from last year. Will it hurt the lawn if I use seed that's out of date? Even if it doesn't grow, it can't hurt to put it down, can it? After all, it's no good anymore, right?
Thanks for the advice.
Old 08-07-2007, 03:50 PM   #7
It won't hurt anything except your expectations if it does not grow.
Old 08-07-2007, 03:54 PM   #8
Mechanical Engineer
Nah, I don't mind. I have a big bag of landscaper's mix that I used to replant my lawn, and it worked really well. I also have a little left over from last year in separate bags. I'll just dump it all on and see what happens.
Thanks for the help.
Old 08-07-2007, 09:15 PM   #9
Eibwen
The proper position to take here is to tell you Girlfriend that the brown spots are supposed to happen because you are preparing the soil for the normal fall "overseeding" and this will help eliminate the weeds. [but water it a lot in the meantime] Then overseed in Sept or so and next spring it will grow like wildfire.
Sammy is offline   Reply With Quote
Old 08-07-2007, 11:11 PM   #10
Mechanical Engineer
Sammy, I like your thinking here. She's already stressing about it and wondering if it will come back. It poured this afternoon. There aren't too many spots that are really bad. Just the areas where the spreader was turned around. I'll keep watering as much as possible. Thanks for the tips.
Old 08-08-2007, 09:51 PM   #11
Eibwen
Tell her this is the plan and EVERYBODY overseed's in the fall during half time of the football game and it will all look nice next spring after all those nasty weed have been killed off by that good fertilzer you just put on.
You'll be a hero!
Good luck!
Old 08-09-2007, 12:32 AM   #12
well i came on here to help you guys out but its all been covered... but i must say that sammy has the right idea lol.
dienam3less is offline   Reply With Quote
