Outdoor Pond - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 08:08 PM   #1
Outdoor Pond
Any of knowledgable people have or have done an outdoor pond before? If so, how involved is it from start to finish? If you have fish, what do you do with them in the winter?
Breakthecycle2 is offline   Reply With Quote
Old 04-29-2011, 12:30 AM   #2
Too Short? Cut it Again!
You want to think through what you want from the pond if you plan on fish you want to make sure it is deep enough predators cannot get at them. Especially if you are in raccoon country.
Don't skimp on the base for the shape and use a double layer of flexible liner. Don't buy those stupid molded shaped things.
Other issue is what to do with the fish in the winter. One friend in Central Illinois has a gorgeous pond he keeps heated somewhat all year so his Koi do not freeze. Another has fewer fish and just plunks them in a household aquarium for the few critical winter months. Gets a little crowded but they do fine.
Obviously you need to plan the rest of the ecosystem and what plants in the water and near it to add. You might want to add some flowing water feature like a fountain or waterfall to keep it from gucking up too much from algae and stuff. Watch yard fertilizer and nitrogenized grass clippings getting into it.
If you are thinking of a much bigger pond see my post elsewhere and links about natural swimming pools. No chemicals, cleaner water than a pool as most of us no them and almost zilch maintenance.
Old 05-05-2011, 03:52 PM   #3
If you need some help let me know. I don't build for a living, I just did mine because most don't know how to build a proper pond. Mine is a Koi only pond and it is a difficult build, if it's to be done right so you can enjoy it. The fish stay in the pond during winter the water only gets to the low 50*.
Old pond before I educated myself.
Filters
JohninSC is offline   Reply With Quote
Old 05-05-2011, 03:56 PM   #4
Finished
Old 05-05-2011, 06:53 PM   #5
Wow, that's pretty much what I was looking at doing. How much did it cost if you don't mind me asking?
Old 05-05-2011, 07:34 PM   #6
I would say close to 8k not including the decking.
Old 05-05-2011, 07:38 PM   #7
Learning by Doing
Leah Frances's Avatar
WOW - that's one hell of a pond. NICE work!!!!
No ponds for me. I could never keep my dogs out of it
My parents have a MUCH smaller pond - they just leave the goldfish in all year - some of them die off in the winter, but nature takes it course and they make new ones in the spring.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-05-2011, 08:05 PM   #8
Wow, what cost the most?
Old 05-05-2011, 10:01 PM   #9
The filtration cost the most, as you can see I did DIY some of it and bought most of it. The smaller filter (nexus) was 2k, the UV lighting cost 1500 and I have 220 watts of it. Then you have a skimmer, 4" bottom drains with air, 4-2" return lines for a total of 9000gph.
Old 05-09-2011, 01:45 PM   #10
pond
Hi I dug a bathtub size pond in my back yard one year,,, and linned it with some rubber I got from lowes,, it is 3 ft deep and now its the size of 2 tubs,,, and as soon as I can in spring I get out there and drain it out hose it and refill it and put the filter in it and let it run for a day or so with some salt,,,and then put the fish out,,I have a bath tub size pool in my plant room and they are kept inside over the winter,, as our winters are to cold to keep them out ,,we have a lot of maple trees around here and we have to many dead leafs that would make the pond nasty in winter and I dont have a heater to float in the water to keep the water open for air either,,and they have to have air and water flowing all winter,,,
dholmer is offline   Reply With Quote
Old 05-09-2011, 04:42 PM   #11
licensed electrician
nice f-in work! my head would explode trying to wrap my brain around a project like that
The Deez is offline   Reply With Quote
Old 05-13-2011, 08:54 AM   #12
Thanks It takes some time and planning but it's not too bad.
Old 05-25-2011, 05:36 PM   #13
Fantastic!
Nice work on your pond- thanks for posting pictures. sdsester made a good point. I had a pond that I stocked with koi fish but I experienced the problem of predators feasting on them. It wasn't nice.
PaulSimmons is offline   Reply With Quote
Old 05-25-2011, 06:12 PM   #14
That's one reason why I have vertical walls that go 5' down they can't stand in the water and the Sail shades prevent any blue heron from seeing them.
Old 05-25-2011, 07:09 PM   #15
predators
JohninSC, that was smart. Looks and sounds like a thorough job!
