Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-16-2009, 08:55 AM   #1
Outdoor lighting transformer problem
good morning,
had a GFCI recepticle installed with a plastic cover. Transformer is 150 watt, bought a 6-light landscape combo, totalling 112 watts total. Added another 11 watt fixture. Has been fine for about a month but the lights stopped coming on at dusk so I checked the transformer and the plastic where one of the prongs is inserted has melted. I can still unscrew the screw but does anyone know why this would happen?
thanks.
LC
lindapalmbay is offline   Reply With Quote
Old 09-16-2009, 09:05 AM   #2
Remodeling Contractor
You may have overloaded the transformer. You have accounted for the total watts from the lamps but not for the voltage drop in the wires and connections and transformer efficiency. Buy a larger transformer.
Old 09-16-2009, 09:18 AM   #3
hi Bob,
thanks for the reply. That's what I figured. I thought I might take off the extra fixture I had put on but since the plastic has melted I don't think that's a good idea.
Linda
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
When a pole transformer goes bad KE2KB Electrical 39 12-03-2008 10:44 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
