Our Lawn = Mud Pit In The Winter, Dustbowl In The Summer!? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 12:46 AM   #1
Our lawn = Mud pit in the winter, dustbowl in the summer!?
Sorry about the long post but here goes... About two years ago my wife (against my advice paid a contractor a lot of money to come in and landscape our yard. It looked amazing at the time but as I pointed out to him at the time, if the drainage was not taken care of then this was all a waste of time.
Back to the present (two years and one divorce later. Yes, seriously!) the whole grassy area looks like hell: it floods in the winter and becomes a desert in the summer with only patches of grass able to cling to life here and there.
I'd like to rectify this and want some opinions/ advice.
I live in the Pacific Northwest = LOTS of rain and heavy clay soil. The water table is quite high as there used to be steams running through the area. So, I'm thinking french drains (running into solid pipe connected to a sump which I built to catch the drain tiles and downspouts) 1" layer of sand, fabric, 4"new graded top soil and sod.
I've attached photos to give a clearer idea of what I'm doing.
In the middle of the trench that I've dug you can see the "rock pit" that the contractor put in and which was ineffective. On the last two shots you can see that after two days of hot dry weather the 4" of topsoil is dried out, grass is all but dead but the bottom layer of clay soil in still holding lots of moisture.
Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5152419.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5152420.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5162432.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5162433.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5172438.jpg
WayneGee is offline   Reply With Quote
Old 05-18-2012, 06:51 AM   #2
Stay-at-home GC
Two suggestions from The Village Idiot.
If you're going to add sand and top-soil make sure you remove that much of the existing elevation or you'll bury the edges of your sidewalk/patio (a maintenance nightmare) and possibly bring the grade high enough to cause moisture problems with the house.
I assume you mean an active sump pit with a pump vs a dry-sump. Is there anyway to make the system passive (no pump)?
Not sure about the sand layer but we don't have a lot of clay here in SW PA
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-18-2012, 08:34 AM   #3
PA
Thanks for the response and to answer your question, the sump system is passive. I built it when I did the drain tiles etc two years ago and it works great.
Old 06-11-2012, 05:20 PM   #4
Here's a few pics of the process and final product..
Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5252471.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5252473.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_5262480.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_6032483.jpg   Our lawn = Mud pit in the winter, dustbowl in the summer!?-_6032486.jpg
Tags
clay soil , drainage , french drain , soil , top soil
Building an Arbor for summer with the ability to store wood in the winter. lorraine55 Carpentry 14 01-31-2012 09:46 AM
Upstairs...HOT in summer, cold in winter Dooggins1 HVAC 26 10-27-2011 07:44 PM
removable/reusable window coverings for winter on summer cottage michigan girl Insulation 7 09-13-2011 04:54 PM
Lawn and summer heat question Breakthecycle2 Landscaping & Lawn Care 39 07-29-2011 09:52 AM
Summer / winter differences... buggie Building & Construction 3 12-24-2005 09:34 AM
