Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 04-11-2010, 06:06 PM   #1
Ooops! Gas oil mix in lawn mower
My lawn mower accidently got filled with the gas oil mix instead of the gas can. Can this be fixed or will I have to buy a new lawn mower? If so, how do I do this?
jamibe is offline   Reply With Quote
Old 04-11-2010, 06:25 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Draining a mower gas tank is easy, with pliers.
Old 04-11-2010, 06:37 PM   #3
the Musigician
DangerMouse's Avatar
if you haven't run the machine, just tip it upside down and drain it. it likely won't do any damage. it'll burn off fast.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-11-2010, 06:54 PM   #4
it will probably smoke for awhile but that will go away
The older I get the better I was
Old 04-11-2010, 11:46 PM   #5
Just run the mower like normal, outside of the little smoke from the 2 cycle oil, no issues otherwise likely to be seen.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 04-11-2010, 11:55 PM   #6
nap
You talking to me?
nap's Avatar
if by chance you end up running some of the oil gas mix, the worst the is going to happen from that little bit is you might foul the spark plug. If after running it with the plain gas it doesn't seem to run as well as it did before, you might try replacing the spark plug with a new one.
Old 04-12-2010, 09:52 AM   #7
This is a lot less problematic than putting the plain gas in the 2-cycle engine!
operagost is offline   Reply With Quote
Old 04-12-2010, 08:11 PM   #8
Go find a plastic disposable turkey baster at the dollar store.
handy man88 is offline   Reply With Quote
Lawn Mower Not Starting - Any ideas? topgun129 General Discussion 1 07-16-2009 07:52 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 02:22 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 03:37 PM
