-   -   Ooops! Gas oil mix in lawn mower (http://www.diychatroom.com/f16/ooops-gas-oil-mix-lawn-mower-68824/)
jamibe 04-11-2010 05:06 PM
My lawn mower accidently got filled with the gas oil mix instead of the gas can. Can this be fixed or will I have to buy a new lawn mower? If so, how do I do this?
Yoyizit 04-11-2010 05:25 PM
Draining a mower gas tank is easy, with pliers.
DangerMouse 04-11-2010 05:37 PM
if you haven't run the machine, just tip it upside down and drain it. it likely won't do any damage. it'll burn off fast.
DM
tpolk 04-11-2010 05:54 PM
it will probably smoke for awhile but that will go away
AndrewF 04-11-2010 10:46 PM
Just run the mower like normal, outside of the little smoke from the 2 cycle oil, no issues otherwise likely to be seen.
nap 04-11-2010 10:55 PM
if by chance you end up running some of the oil gas mix, the worst the is going to happen from that little bit is you might foul the spark plug. If after running it with the plain gas it doesn't seem to run as well as it did before, you might try replacing the spark plug with a new one.
operagost 04-12-2010 08:52 AM
This is a lot less problematic than putting the plain gas in the 2-cycle engine!
handy man88 04-12-2010 07:11 PM
Go find a plastic disposable turkey baster at the dollar store.
