OMG! What's Happening To My Lawn? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 04:41 PM   #1
Cape Cod, MA
Rewards Points: 81
OMG! What's happening to my lawn?
Hey folks, I have a serious problem with my lawn. Starting late last year, I started to notice these brown spots in my lawn. For the past month, my lawn has been covered with snow. Since the snow has melted this is what my lawn looks like.
Last March roughly a year ago, I completely removed the old turf, layed down
Loam, and re seeded everything. I had great-looking grass until this began. Any info would be greatly appreciated.
Aaron
capecodder is offline   Reply With Quote
Old 03-02-2013, 04:45 PM   #2
Rewards Points: 13,270
It's up side down so now the rain can not get to it.
http://www.scotts.com/smg/templates/...Url=helpCenter
Old 03-02-2013, 04:51 PM   #3
Rewards Points: 12
It's likely from the snow. I have some spots like yours in my lawn. Those areas were reseeded in the fall.
If the brown spots turn white, it could be snow mold and is a result of fertilizing too late in the season.
Just be patient. Wait for the grass to start growing this spring then rake it out. Patience is the key.
djlandkpl is offline   Reply With Quote
Old 03-02-2013, 04:57 PM   #4
Cape Cod, MA
Rewards Points: 81
I did reseed again in the fall, first week of October and laid down starter fertilizer. I was about to mention, that when I went out there today I actually saw mold under some of the dead grass. I'm assuming that I will need to reseed again is that correct?
Aaron
Old 03-02-2013, 05:05 PM   #5
May need to dethatch it in the spring to get rid of the dead grass.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
concretemasonry (03-02-2013), creeper (03-02-2013)
Old 03-02-2013, 05:26 PM   #6
Rewards Points: 12
Aaron
You might have to reseed some spots. A few years back I had snow mold really bad. It took almost all season but it filled in by itself. Wait until you've cut the lawn at least once then rake it out. Water it, fertilize it and then wait. If it doesn't fully recover, reseed in the fall.
Old 03-02-2013, 06:00 PM   #7
Cape Cod, MA
Rewards Points: 81
Is there anything that I can do to prevent this from happening again? Does the ground need to possibly aerated?
Old 03-02-2013, 06:47 PM   #8
Rewards Points: 12
I wouldn't aerate at this point. You'll do more damage than good. Snow mold is a result of too much nitrogen when it gets cold. Starter fertilizer is mostly nitrogen.
Just watch the amount of fertilizer you put down in Oct/Nov. Our winters have gotten so screwy its hard to know when we will get snow and when the ground will freeze.
Old 03-02-2013, 07:30 PM   #9
Cape Cod, MA
Rewards Points: 81
Here's the thing. I'm going to be digging up the ground to install a new irrigation system. In the following weeks I was thinking of dethatching, the. Installing my system then reseeding the damaged areas and those caused by the irrigation digging. Sound like the right way to do it?
Thanks for the help!
Old 03-02-2013, 07:41 PM   #10
Rewards Points: 12
Your plan should be OK. Just wait until the grass starts growing or you'll pull up good grass along with dead.
If you use a ditch witch to pull the pipe the damage should be minimal. Definitely reseed the areas affected by your irrigation system.
(I stopped doing any seeding in the spring due to the amount of water needed to keep it alive during the summer.)
Old 03-02-2013, 07:58 PM   #11
Cape Cod, MA
Rewards Points: 81
Should I apply starter fertilizer as normal?
Old 03-02-2013, 08:04 PM   #12
Rewards Points: 12
Yes, apply fertilizer. The only time your run the risk of mold is fall.
Please help with my ridiculous front lawn slope billyh Landscaping & Lawn Care 14 05-20-2012 08:46 PM
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 01:45 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
lawn needs help ursula Landscaping & Lawn Care 9 01-31-2010 12:19 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
