An Older Murray Riding Lawn Mower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 09:41 PM   #1
an older murray riding lawn mower
my murray riding lawn mower won't even start i mean nothing won't crank over or any thing no sound turn the starter switch and no sound no nothing whats wrong i've check everything
CHADABL is offline   Reply With Quote
Old 05-27-2011, 09:52 PM   #2
Anyone I have an older murray riding lawn mower, that won't start or turn over nothing the battery is charged up installed a new sparkplug check all the wires, clean the battery posts, changed the oil (New Oil) New oil filter it won't crank over its electric starter turn the switch nothing whats wrong with my murray riding lawn mower
Old 05-28-2011, 06:44 AM   #3
Rewards Points: 1,574
Does it have a seat interlock (you get off the seat and the engine shuts off)?
If so, may be a problem with wiring in that system; if not, you'll have to trace the wiring of your starting system for faults, starter could be bad. I'd get a small engine repair manual for your engine brand (avail on line and in some small engine repair/sales stores; maybe in auto parts place as well).
bob22 is offline   Reply With Quote
Old 05-29-2011, 03:09 AM   #4
Rewards Points: 256
remove that small front panel under the steering wheel there should be a cylonoid in there . you can try bypassing the cylinoid by taking a screw driver and touch the positive to the side terminal . if it turns over then its your cylinoid. make sure your blades arent engaged first.
oldrivers is offline   Reply With Quote
Old 05-30-2011, 09:06 AM   #5
In case oldrivers' advice worked, you will need a solenoid, the approved spelling for cylinoid.
Old 05-30-2011, 01:49 PM   #6
Rewards Points: 256
thats true but when someones helping you save 200 dollars on a repair then i wouldnt care how its spelled , id be happy just to get it fixed.
Old 05-31-2011, 07:02 AM   #7
Agreed, I just wanted him to know that if your good advice helped, he would know how to search for the right part (in case he has no idea what to call it)
murray riding mower wont start ColbyZ Landscaping & Lawn Care 15 07-08-2012 07:54 PM
Murray riding mower wont start again ezthinkr Landscaping & Lawn Care 3 05-15-2011 11:15 AM
Riding Lawn Mower dieing out after using it for 10 mins. topgun129 Landscaping & Lawn Care 5 09-01-2010 07:10 PM
murray lawn mower herbl38 General DIY Discussions 6 04-27-2008 10:16 AM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
