Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 11-01-2011, 06:05 PM   #1
Oldcastle retaining wall blocks
Hi,
I am trying to build a retaining wall with Oldcastle retaining wall blocks. Lowe and Home Depot have them but in 12" size. I want to buy the 16" but heard that they are only available for contractors. I really appreciate if you can tell me where to get those blocks. I live in Dallas.
Thank you.
Kim
ktran is offline   Reply With Quote
Old 11-01-2011, 06:14 PM   #2
concretemasonry's Avatar
Oldcastle makes them under a license from one of the several different licensors.
The license may have requirements on what sizes are sold, because often the larger sizes are frequently mis-used in higher walls by DIYers.
I assume you are referring to the length of the units or is it the thickness of the walls? The height would be somewhat less than 8". there are many different sizes made in the world, but for walls higher the 4' or 5' (up to 40'high), they must be engineered. Larger size units may be available elsewhere, but there usually is no technical support on the use.
Dick
concretemasonry is offline   Reply With Quote
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Retaining Wall - Stones and Support? revkev1952 Landscaping & Lawn Care 3 08-09-2010 03:02 PM
Retaining wall Hurriken Landscaping & Lawn Care 7 09-22-2009 12:26 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
