Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-21-2012, 09:54 AM   #1
oil viscosity
I hope this question is appropriate for this forum. Can anyone suggest the correct oil viscosity for lawn mowers and heavy duty gasoline leaf blowers. I have been using 10/30 wt. I hear different thoughts. Thanks
pokey is offline   Reply With Quote
Old 10-21-2012, 10:01 AM   #2
oil viscosity
That should be fine. I've been using it in all my equipment for 30 plus years and never had an engine failure.
My Z turn is 5 years old and mows at least 6 lawns a week. No smoke and still has great compression.
In a snow blower I would concider using 5W-30 for easyer starting.
Old 10-21-2012, 10:09 AM   #3
sdsester's Avatar
oil viscosity
Important thing is to change it often in small engines as they do not have the filter capabilities of say a car engine. You should certainly change it when putting the machinery up for the winter and I used to make a point of changing it at least once during the season.
sdsester is online now   Reply With Quote
Old 10-21-2012, 10:28 AM   #4
oil viscosity
I appreciate the info. Thanks
Old 10-21-2012, 07:27 PM   #5
oil viscosity
Most if not all manufacturers call for straight 30 weight in a 4 cycle engine,but 10w30 should be a good alternative.
Canarywood1 is offline   Reply With Quote
