Oil In JD 318 - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 07:38 PM   #1
Rewards Points: 774
Oil in JD 318
The guy I bought it from said to use detergent 30 wt. I believe....does that sound right? Just wondering.
cibula11 is offline   Reply With Quote
Old 09-18-2011, 07:56 PM   #2
A Little Of Everything
Rewards Points: 1,364
"Detergent 30 wt"? Typically, unless an oil is labeled "non-detergent" it has detergents.
Anywhoo... Regular, straight 30W oil will be fine during the summer. But if you're going to use this beast to blow snow in the winter, you'll want to go with a multi-vis, such as 20W50.
Also, if you're going to use it a lot in the winter, you could go with a heavier synthetic oil, because synthetics flow easier in extreme cold than do dino oils.
On a personal note, when my sons & I were doing our lawn mowing service, I added some Lucas Synthetic Oil Stabilizer to all my small engines. It may have been purely coincidental, but I never had an engine failure after I started using it.
DrHicks is offline   Reply With Quote
Old 09-18-2011, 09:36 PM   #3
Rewards Points: 774
I figured "detergents" were typically used, but thanks for clarifying. Good to know about the synthetic stabilizer.
