Newly Laid Sod - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 07:32 PM   #1
Rewards Points: 95
Newly Laid Sod
About 2 months ago I laid down sod. Half of it died. The supplier agreed to replace it so 2 weeks later I mowed the good sod and replaced the dead sod.
I waited 2 weeks and mowed. It's now a another 2 weeks later and I will mow again. It looks good but there are spots where crabgrass is growing.
So it's been a total of about 2 months total since it's been laid down (1st section 2 months old and second section 1 month old).
Can I use Weed and Feed? It was hard work doing this and I am afraid of killing it but I don't want the crab grass to take over AGAIN.
I thought about pulling the crab grass out but then it would probably grow back.
Can anyone please advise of what I should do. I really don't have a GREEN THUMB.
Thanks.
grod777 is offline   Reply With Quote
Old 07-21-2012, 08:42 PM   #2
Rewards Points: 2,638
You mention several times about how often you mowed it, but how often did you water it? In all likelyhood, the grass died because it did not get enough water.
Spring and fall are the best times to be putting down sod. Summer is too hot and dry (unless you water it at least once a day). Where are you located?
For the crabgrass - get out your needle-nose pliers and yank it out.
SPS-1 is offline   Reply With Quote
Old 07-21-2012, 09:06 PM   #3
Rewards Points: 95
Water it twice a day but it started to brown the next day and only certain spots.
My only concern is the crabgrass right now.
I'll pull out the crabgrass with my pliers but when is fertilizing OK?
Old 07-21-2012, 09:39 PM   #4
There will be posts from people that know more about sod than me, but honestly, I am not sure when best to fertilize. I did some repairs with sod in the spring, and fertiled about 4 weeks later. But weed and feed is not going to do anything for crab-grass anyways. You will find weed and feed that will get rid of crab-grass, but when you read the label, it will say to put dit down in the spring before the seeds come up.
Newly laid sod Maint. tips???? dobrien1030 Landscaping & Lawn Care 8 06-12-2012 09:03 PM
Cleaning newly laid brick rightit Concrete, Stone & Masonry 11 03-17-2012 10:04 PM
large, soft areas in newly laid tongue & groove floating floor dfeigin Flooring 0 08-15-2011 01:19 AM
how easy should newly laid tile come up classicaaron Flooring 3 07-14-2011 05:29 PM
Plastering on newly laid brickwork? djj66 Building & Construction 10 09-21-2005 12:01 AM
