New Front Walk - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 07:19 PM   #1
Rewards Points: 236
new front walk
this is what i did today. the upper teir, the lower stayed as is was. there ussed to be a drive on that side of the house, so the walk went out that way. no use for it now, and i want more grass. which leads to my question. where i removed the pavers, there is sand and stones. can i just put dirt over that, or do i have to remove it ? its about 4" of fill if i just filled it.
the new walk section. i didn't try to make it perfect, but it does look pretty good.
Fix'n it is offline   Reply With Quote
Old 03-31-2013, 07:42 PM   #2
Rewards Points: 1,008
You might be able to grow grass there if you feed it 3 meals per day of Miracle growand it would still be a miracle. I recommend removing it and replacing with GOOD top soil and not something some business cleaned from a culvert pipe and called top soil.
SeniorSitizen is offline   Reply With Quote
Old 04-01-2013, 09:16 PM   #3
Rewards Points: 236
yeah. thats what i thought.
Old 04-02-2013, 12:30 AM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
Walkway looks nice.
As Fairview said, most grass needs at least a few inches of good topsoil unless you want to constantly be babying it.
fetzer85 is offline   Reply With Quote
Old 04-02-2013, 08:13 PM   #5
Rewards Points: 236
well, like i said. to just fill it in, would be over 4".
i don't have a problem digging that out. except for moving it to where idk yet.
Old 04-02-2013, 08:29 PM   #6
Roofmaster
Rewards Points: 2,172
Just till it to loosen it up and put 4 inches of black topsoil over it. As long as water can percolate down through it you should be fine. I have one of those little Honda tillers and the thing is amazing for its size, it would chew this right up.
Old 04-03-2013, 09:13 PM   #7
Rewards Points: 236
i have started digging it out.
What to do about a Damp Crawl Space under front porch? vpr80 Building & Construction 9 04-11-2012 08:32 PM
chest freezer front lid seal. 4just1don Appliances 1 04-02-2012 07:56 AM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
