Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-12-2013, 06:03 PM   #1
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Neighbors gutters pushing water near my foundation.
Is there any code issues if my neighbours gutters face towards my home and push a large amount of water near my home causing puddling that don't normally happen around my foundation. I am concerned about water problems since they just recently did the gutters.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 06:06 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Donno 'bout Granville, but generally, Ya, yer responsible for run-off from yer property...
Have ya spoke to 'em 'bout it,..?? that's usually the 1st step...
Bondo is online now   Reply With Quote
Old 02-12-2013, 06:11 PM   #3
rrolleston's Avatar
Yeah they are not the type of people to listen to what I am trying to do. Have tried that part. My next though was code enforcement.
Old 02-12-2013, 06:43 PM   #4
rrolleston's Avatar
Just trying to keep as much water off my property as I can. The water for my roof is enough without the neighbours shooting their water over on my yard.
Old 02-12-2013, 06:45 PM   #5
concretemasonry's Avatar
Your yard is probably lower than theirs. When were the homes built? Where does you roof drainage go and how much does it contribute to what is in your yard?
Dick
concretemasonry is offline   Reply With Quote
Old 02-13-2013, 01:39 AM   #6
rrolleston's Avatar
Homes have been here about 30 years yes mine is lower but never noticed till they installed gutters and faced the drains towards my home.
Sent from my iPhone using DIY Forum
Old 02-13-2013, 07:26 AM   #7
Bondo's Avatar
Ayuh,.... Is there enough room 'tween the houses to trench in a swale, to move the water away from both houses,..??
Old 02-13-2013, 01:19 PM   #8
You need to regrade the land so, after the water pours out of your neighbor's gutters against your foundation, it does not stay there.
Nothing to do with your neighbor. The water from your own roof is not supposed to stay there either.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 02-13-2013, 09:09 PM   #9
how far apart are the houses, and how far is the end of their gutter away from your house ? pics
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-13-2013, 09:39 PM   #10
Average Joe/ex-Navy IC3
gregzoll's Avatar
Maybe work with them, in installing a large enough tile to take the water from both your downspout and theirs, and use a common run to push it down away from the homes, under the ground. Or the other, is if they go half on materials, and help with labor if they are capable, maybe both of you could lay two sets of drain tile for both homes, just off the split of the property line.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 02-13-2013, 10:07 PM   #11
JOATMON
ddawg16's Avatar
Not that I would do it....but if someone were to take can of Great Stuff (expanding foam) and point the nozzle up the rain gutter....give it a good squirt....it would stop the water from gushing out....
But like I said, it's not something 'I' would do....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Advice on Retrofit Water Drainage For Foundation 4 FT Under cloves Building & Construction 13 04-07-2010 11:47 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
