Need Help Stripping Sealer From Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 01:11 PM   #1
Need help stripping sealer from concrete
Hi Everyone,
I have stamped concrete patio where the sealer has all started to peel up. So I need to strip it and have it re-sealed. The problem is I think I have an oil based sealant on top of a water based one. Does anyone know any product(s) I can use to strip everything off so I can start over?
ChaoticBliss is offline   Reply With Quote
Old 05-26-2011, 05:18 PM   #2
Too Short? Cut it Again!
If you are right in your assumptions? Oil based things, with exceptions, cannot stick to water based---usually acrylic underneath.
There is another possibility here though. Someone may have sprayed the last layer with something like Thompson's Water Seal which has wax in it.
Good news? If the top layer is all coming up?
Powerwash it and see what you have with that peeling layer out of the way.
Old 05-26-2011, 08:55 PM   #3
Well what happened was the first coat was already about half peeled up when the second oil based coat was applied. The concrete actually has two different colors now, dark where the oil based is and light where the water base is. The second coat was done professionally so I don't think it is something like Thompsons. Power washing has been tried and only removed any loose sealant.
Old 05-27-2011, 07:10 AM   #4
Concrete & Masonry
Rewards Points: 568
I'd be careful with the power washer, as too much pressure concentrated in one spot too long can and will do damage to the surface.
Here's a "stripper" I've used before to remove some water-based. There are others out there as well, but you'll need to get them from a concrete supply house. My experience with the stripper is that it doesn't go very fast and still takes a lot of effort to get the sealer off.
http://www.wrmeadows.com/wrm00170.htm
When you get to re-sealing it, I'd suggest on only using a solvent based sealer, less chance of running into this problem again by doing so. You can almost always spray WB over solvent w/o problems, but rarely ever the other way around.
jomama45 is offline   Reply With Quote
Old 05-27-2011, 07:24 AM   #5
Thanks. I will try and find a supplier of that near me.
Do you think I should try an oil based stripper first since that was put on most recently? There are areas where only oil based sealer is on the concrete (areas that were bare when it was sealed). Or wil this stripper take off both?
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls myhouse2010 Building & Construction 1 10-17-2010 11:35 PM
Basement Poured Concrete Sealer DAdams982 Remodeling 1 07-25-2010 05:48 PM
Stamped Concrete Sealer cgoll Building & Construction 1 06-24-2008 06:15 PM
