Need Help With Privacy Fence - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-23-2010, 12:39 PM   #1
need help with privacy fence
i am building a privacy fence but i am unsure how to attach it to the house. it is a brick house with 6 foot sidewalk around it. i need a way to attach the 4x4 post to the brick on the house so that it will be stable.
internal is offline   Reply With Quote
Old 06-23-2010, 01:38 PM   #2
Handyman
Rewards Points: 512
Three 1/4" galvanized lagbolts 5" long with lead anchors. Top, bottom and middle. Be sure to anchor into the brick, not the mortar, and fill each hole with silicone caulk before you install the anchors.
Predrill the holes in the post so that the lag goes cleanly through and use galvanized washers to hold the post into place. If you wanted to you could recess the lags by drilling a hole with a spade bit (before you drill the hole for the lag) the same size as the washer about 3/4" in.
canadaclub is offline   Reply With Quote
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 01:19 PM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 01:38 PM
Privacy Fence on one side? caseydm Landscaping & Lawn Care 9 10-28-2008 10:13 AM
Privacy Fence Post 10' Apart wrldruler Building & Construction 6 09-02-2008 10:59 AM
Privacy Fence Gate Dallas Carpentry 8 11-20-2007 08:12 PM
