#1 |
Need help - old Toro 7/24 snowblower I am having difficulty accessing the impeller bearing of an old Toro 7/24 snowblower (serial number 38050). I cracked the machine into two sections and removed the pully from the impeller, to expose the end of the impeller shaft (please link to the below photo). As seen in the photo, there is a small, long, rectangular piece of metal stuck to the shaft. I would like to slide the old impeller bearing off of the shaft, but can't because of this small, long, rectangular piece of metal. Any advice from someone who has dealt with this type of problem before would be really appreciated.http://www.flickr.com/photos/56659718@N07/5233026762/ |
#2 | |
Need help - old Toro 7/24 snowblowerQuote:
Why don't you try removing the 3 nuts off those 3 threaded ends? |
#3 |
Looks like a key to me as well; you should be able to push, pull, and/or yank it out of the groove it is in now.
| Display Modes | |
| does anyone know how to replace toro 924 snowblower shear pin? | tgomar | Landscaping & Lawn Care | 4 | 03-23-2009 02:53 PM |
| Toro 7/24 Snowblower - friction wheel | Ottawa | Landscaping & Lawn Care | 1 | 02-02-2009 09:01 AM |
| Toro snowblower adjustments | Tom Fraser | General Discussion | 1 | 01-03-2009 07:04 PM |
| Toro snowblower | tuna Ted | General Discussion | 2 | 01-01-2009 06:20 PM |
| Toro SnowBlower 521 metallic sound | mteach | General Discussion | 1 | 12-13-2007 01:27 PM |
