Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-01-2012, 10:44 PM   #1
Need help with flooding backyard from neighbor
Is there something I could do to prevent the neighbors water from going into my backyard?
I noticed that water enters on the right side of the fence (as viewed from the photo). The water also goes into the neighbor to the right of me (as viewed from the photo).
I could try to raise my backyard by putting a lot of dirt, but not sure if dirt will solve the problem. I have a few inches of mulch near the fench, so I could replace it with just dirt and raise the back area a few inches.
But the main area that flooded is about 8 inches below the back fence area.
Any suggestions.
Need help with flooding backyard from neighbor-flood1.jpg   Need help with flooding backyard from neighbor-flood2.jpg   Need help with flooding backyard from neighbor-flood3.jpg
greentrees is offline   Reply With Quote
Old 07-02-2012, 12:20 AM   #2
"Is there something I could do to prevent the neighbors water from going into my backyard?"
The simple answer is probably not. Most US States observe some form of the Civil Law of Drainage. Since you didn't say where you are I have no way of knowing what law might apply.
I suggest you not fill or otherwise block the neighbors water until you know whether you have a right to do so. Back water up on his side and you might have to pay damages, tear out the work you did, and if he has to take you to court that cost may fall on you too.
pls8xx is offline   Reply With Quote
Old 07-02-2012, 07:37 AM   #3
sdsester's Avatar
I've mediated a number of these situations and usually end up recommending all involved neighbors split the cost of a civil engineer or landscape architect and the cost of fixing the grades. I know it is un American to suggest their are alternatives to going to court over disputes but usually you can work things out. Sometimes not.
By the way, I have had a judge or two sign off in including the land developer in grade restoration a time or two. The were not happy but they are the ones that scraped the land and did not return it to a decent drainage situation.
sdsester is offline   Reply With Quote
Old 07-02-2012, 08:38 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
I am going to make a guess. Most likely it is coming from the high side to the left, not from the back that you think that it is. Only way to fix the problem, is everyone together find a solution, not just place a band-aid on one part of the problem.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-03-2012, 12:40 AM   #5
Wow. Didn't think it was a legal issue. This is a tract home area in California that is flat, with thousands of homes in the area. There is a street in front of both houses, so I would think the water should flow from the backyard to the street, not thorough someone elses property.
The picture is deceiving. The ground is actually flat, so the fence is actually level. There is another fence that the neighbor has with a space of about 1 foot between the two fences.
Tags
drain, flooding backyard
Landscaping Ideas for Small Backyard? gammy4gks Landscaping & Lawn Care 2 08-08-2011 09:25 AM
lowering backyard level & window to crawl space greenpointer Building & Construction 2 03-14-2011 08:40 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 05:50 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
