Need Help - Failed Patio In Sand Install - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 08:43 AM   #1
Need Help - Failed Patio in Sand Install
I have a pool that was installed on a hill. The excavations were spread around the pool to create the area for a patio surround. There was some rock in the pool and apparently this was included in the the fill for the surround.
A mason contractor then came in and laid limestone pavers (about 1 3/4" thick -- maybe 6x12 rectangle). The dirt is loose clay (sandy clay). It was laid in rock dust - a blue stone material we have around here (Chapel Hill NC) - it goes from 3/8" down to dust and is sharp edged. We also have decomposed granite (we call Chapel Hill gravel), which is what I'd expect for a base but it doesn't seem to be used.
Of course is has settled (now 2 years old). The contractor did come back a year ago and fixed some bad areas. This time he was mixing rock dust with cement and then relaying them. This helped but it still settled some. No polymeric sand was used. The edging is that plastic angle stuff with the landscape spikes (which doesn't work well with such thin pavers). The contractor wasn't bonded and he's now had a stroke ... out of the picture.
I'm pretty broke from the project and so I'm faced with fixing the mess. I'm not the young whipper snapper that I once was, so I'm going to have to do it in sections. I've read on Pave Tech how to do the job right and clearly it was not done correctly.
I think I know how to do this by starting all over (excavate for a 4" base and 1" of bedding sand - probably use geotex under the base - use 1" metal pipe for the bedding sand. compact fill, compact base, don't compact sand, compact pavers - use polymeric jointing sand, compact again.
But that's big, big job. And unless I buy a plate compactor, doing a section at a time is problematic. I've got a hand tamper.
So, does anyone have some suggestions on not so perfect solutions? If I relaid it and used a polymeric jointing sand, would that keep enough water off to prevent more settling? After 2 years, its got to be close to being fully settled. What about using cement with the rock dust, like the contractor did, along with polymeric sand?
Need some help.
lews is offline   Reply With Quote
Old 04-14-2010, 09:33 AM   #2
Military Mom of 4
Snav's Avatar
Have pictures?
How much of a slope are you talking about?
Is there any sort of a retainment wall at the base of the hill or at the end of the pool area to give stability?
I have a feeling that your issue is overall settlement of the entire hillside that's been disturbed - not just the bedding that the pavers are nested in. So, you can fix and fix the bedding - but as the underground continues to settle or slide downhill then your problem will continue to grow.
Lack of a retainment wall will permit the hill to shift - the entire hillside, or sections, will slide downhill.
Untamped, or partially tamped earth will settle naturally - a retainment wall won't necessarily help this, this is just compression of the soil.
I'll let other's dive into your possible solutions - I don't have much experience in that area.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-16-2010, 07:02 AM   #3
Somehow my reply didn't get posted. I'm pretty certain it is not the whole thing moving downhill. The slope of the hilll is modest and the rough grade is conservative - ie, the slope of the downhill side of the patio fill is gentle. Also, the settling is spot settling, not the whole side (although there's a lot of spots).
The Following User Says Thank You to lews For This Useful Post:
MurphyMan (10-29-2013)
Old 04-16-2010, 08:05 AM   #4
Here are some photos
Old 04-17-2010, 06:10 AM   #5
GardenConcepts's Avatar
Rewards Points: 150
From the pictures it look likes the pavers have settled below the edge of the pool coping. It also sounds like the fill around the pool is the culprit. If you use fill to build up an area intended to hold a patio, it must be a compactable fill, and compacted extremely well- using a double drum vibratory roller. Even then, the fill should be checked using a proctor test (checks for density) prior to installing the pavers.
In my opinion, you need to pull up the pavers and use a vibratory roller to further compact the base and fill. I would suggest contacting an engineer first. You'll need to be careful not to damage the pool when compacting.
GardenConcepts is offline   Reply With Quote
Old 04-19-2010, 07:34 AM   #6
Okay. Thanks for the advice.
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 01:13 PM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
