Need Help Cutting Cobblestones - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 02:15 PM   #1
Need help cutting cobblestones
Hello, I have 1 ton of 4x4x4" cobblestones and 2 tons of 4x4x8" cobblestones and I want to build a semicircular patio area with a 2.5' circular hole in the middle for a fire pit. My problem is that I don't know how to cut or break the cobblestones to fill in odd spaces. Is there a blade i can buy for my circular saw or do I just need to repeatedly score with a chisel? Thanks! Atlanta Catdaddy
rmacgregor is offline   Reply With Quote
Old 05-28-2010, 10:38 PM   #2
Rewards Points: 410
You need a wet cutting brick saw available at a rental store.
High Gear is offline   Reply With Quote
Old 05-31-2010, 11:17 AM   #3
Concrete & Masonry
Rewards Points: 582
And even with that, you may be in for a suprise if these are real, native stone. If they are hard, I'd try scoring with a saw & chiselling.
jomama45 is offline   Reply With Quote
Old 06-01-2010, 02:00 PM   #4
You can get a quick cut saw from the rental store a 12'' saw would be great rent the diamond blade and you should have no probleams
water attachement works for the saw but does it ever make a huge mess
eco-green is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 09:20 AM
Cutting in Bubbagump Painting 21 11-04-2008 09:23 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
