Need Help Creating A Potting Table - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 07:14 AM   #1
Non-Crafty Newbie
Meenie50's Avatar
Need help creating a Potting table
I have an old metal outdoor table - a small umbrella type with openings all over the top. (no umbrella) I thought it would be good to make into a potting table since the openings would allow it to be cleaned easily.
Any crafty suggestions for making it blend into the yard well and look nice as well as being functional? Or is this totally a bad idea?
Thanks!
Meenie50 is offline   Reply With Quote
Old 02-15-2012, 07:34 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like a good potting table----I suggest you paint it brown or tan so it is not going to show the dirt
Old 02-15-2012, 08:14 AM   #3
Non-Crafty Newbie
Meenie50's Avatar
Good idea, do you know what to do to a metal table to paint it?
Old 02-15-2012, 08:34 AM   #4
Rewards Points: 13,950
Shake can, remove top, and spray about 6" away from the table. Use several thin coats not one thick one.
Flip it over and spray the bottom first.
Use Rustolium paint.
There's going to be lots of over spray so be carefull where you spray it.
Old 02-15-2012, 10:06 AM   #5
DIY staff
Joe has the answer---I use an old restaurant prep table stainless steel and best of all FREE !!
Old 02-15-2012, 11:54 AM   #6
Non-Crafty Newbie
Meenie50's Avatar
Oh good, you don't have to do anything to prep the table first? Or remove the white?
Old 02-15-2012, 11:55 AM   #7
Non-Crafty Newbie
Meenie50's Avatar
Oh'Mike... Free is ALWAYS good
The Following User Says Thank You to Meenie50 For This Useful Post:
oh'mike (02-15-2012)
Old 02-15-2012, 01:16 PM   #8
DIY staff
For the painting---wash the table well---let it dry --really dry----then paint---If it has a shiny paint now--sand lightly to scuff the surface and use a primer first--If rusty--use a rusty metal primer.
Meenie50 (02-15-2012)
Old 02-19-2012, 06:17 PM   #9
Too Short? Cut it Again!
Remove any obvious rust before priming and painting or it will come back to haunt you. Then, no matter what since it is outside, I would use a rust inhibiting primer. Hit all sides with at least the primer.
If you think a round table will stick out too much? You could cut it in half and have two semi-circular shelf like surfaces along a wall or fence. Not sure if you could recycle the supports though.
I would position it somewhere where you can run a water line with a short length of hose and gentle watering wand up through where the umbrella went. So much more handy than dragging a hose around a potting table. Cost you some PVC unless you get real fancy and want it permanently plumbed.
The Following User Says Thank You to user1007 For This Useful Post:
Meenie50 (02-19-2012)
Old 02-19-2012, 08:05 PM   #10
Non-Crafty Newbie
Meenie50's Avatar
cut it in half, cool idea... no idea how to do that, but I'm sure my husband would, lol
Standard or Sliding Mitre Saw? Or table saw? 7.62 Tools 18 05-07-2012 08:53 AM
Indiana Newbie here! Potting table help needed Meenie50 Introductions 1 02-15-2012 03:18 AM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 03:13 PM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 03:18 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
