Need Guidance Bringing Back Pasture - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-29-2015, 11:26 AM   #1
Rewards Points: 14
Need guidance bringing back pasture
We are buying a 7 acre farm. The last few years the pasture land hasn't been well maintained. It's mostly grown in with weeds. It's cut low now but will begin to grow soon. We have a 30hp diesel Kubota tractor and a riding lawn mower so we can pull anything we need to across the land. We want it to work toward being able to let our horses back out on the pasture but need to know where to begin.
How do we thin down the weeds? Do we need to aerate? Do we need to seed? Do we need to fertilize?
Live in Illinois if that makes a difference.
jrhood79 is offline   Reply With Quote
Old 03-29-2015, 11:59 AM   #2
Rewards Points: 416
If the soil is capable of growing native grass and some of that grass is now present, given time it will rejuvenate itself. The reason for weeds is usually over grazing. Very common among small acreages .
Old 03-29-2015, 01:38 PM   #3
ZTMAN's Avatar
Rewards Points: 72
I had about five acres like that. Cut it low, had a neighbor spray with weed b gone. Kept it cut about four inches after that and it looked great.
ZTMAN is offline   Reply With Quote
Old 03-29-2015, 10:05 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 444
A hundred farmers will have 110 opinions. A lot depends on how much lead time you have before you want to use it and how particular/sensitive your horses are to feed. Heck - some are fine eating the weeds! You could rent or pay somebody to disc then harrow it smooth then overseed with a pasture mix (save buying implements for one-time use). Up here you can buy generic mix from the feed store or order custom mix. You'd probably not want to use it for the first season. You also might be able to get away with overseeding alone. In either case you'll want to roll or scuffle the seed in so it contacts the soil to ensure germination. Over grazing in small paddocks can be a problem. Horses turn even well drained soil into something like concrete fairly quickly, then only the weeds grow. Beware of creating a lush paddock unless your horses are growing, working or pregnant. We did and one our horses foundered badly. Good luck. Great lifestyle.
lenaitch is offline   Reply With Quote
The Following 2 Users Say Thank You to lenaitch For This Useful Post:
Bloxxy (04-07-2015), jrhood79 (03-30-2015)
Old 04-07-2015, 11:48 AM   #5
Rewards Points: 6
Weed killer
I used this product on mine and it worked wonderfully. I got it at my local feed store.
hubedori is offline   Reply With Quote
Sump Pump running constantly and spraying water back into pit CubsWin Plumbing 17 01-04-2017 10:25 PM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 05:51 AM
Power goes out in back room & on by it's self!! happy_4_now Electrical 2 11-23-2010 07:09 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
Bringing Old Hardwood Back To Life Midicat Flooring 1 11-04-2007 10:28 AM
