Need Advice About A Pea Gravel Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 09:22 PM   #1
artlover13060's Avatar
Need advice about a pea gravel patio
I'm thinking of using pea gravel to make a patio under my deck. All the info I've read says to put landscaping cloth down to keep the weeds at bay. Nothing grows in the area where I want to put gravel. Is the landscaping fabric still necessary? The dirt in this area is hard compacted Georgia clay with a very thin layer of top soil.
artlover13060 is offline   Reply With Quote
Old 03-23-2010, 06:30 AM   #2
Remodeling Contractor
The landscape cloth is used also to maintain a barrier between the stone and the gravel. So yes, use it.
Old 03-23-2010, 07:34 AM   #3
Bob, there is no stone, just gravel.
Old 03-23-2010, 08:24 AM   #4
Gravel is normally a small round stone. Same suggestions apply
Old 03-23-2010, 09:55 AM   #5
Newbie Bill
Rewards Points: 522
I think what Bob is saying is the landscape fabric keeps the gravel separate from the soil/clay. I think this is even more important if you are using pea gravel.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
artlover13060 (03-23-2010)
Old 03-23-2010, 04:12 PM   #6
firehawkmph's Avatar
Rewards Points: 1,922
Fabric of not, I don't think pea gravel makes a good choice for a patio. Any small, round stone will constantly move when walked on. They don't lock together. You might want to check into some kind of crushed stone that is available in your area. If you get a mix with sizes going from say 3/4" down to screenings, it will stay put pretty well especially if you run a roller or tamper over it. The fabric would be a plus to help support the stone and keep it from sinking into that good ol' Georgia clay.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-23-2010, 04:20 PM   #7
Firehawk - thanks for your suggestion. I will look into the crushed rock. This patio will not get any traffic. It is outside a basement door that has a paver landing. I plan to add a paver foot path to the yard. The main purpose of this patio is to have something that looks better from the view inside the house than a mud bog.
Old 03-23-2010, 04:38 PM   #8
then your gravel will work fine and look better. To avoid the issue mentioned you would place the pea gravel over a compacted gravel bed. only use less than 1" deep and you get a nice wakable and looking surface.
Old 04-03-2010, 08:34 AM   #9
Murphy's law says once you install stone with no fabric then weeds will grow.LOL
Technically stone will hold a little moisture and will hold weed seed. Possible germination could result.
I installed a pea gravel walkway one time thru a mulched garden. Couldn't talk the homeowner out of it. The PG ened up in the mulch and we were called back eventually to replace with flagstone.
Use larger stone or flagstone is nice as well.
Bushman is offline   Reply With Quote
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
Looking for inexpensive patio advice fabian Landscaping & Lawn Care 6 06-17-2009 08:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
Patio Door Advice Mikedks Remodeling 2 12-18-2006 09:31 AM
Patio & Carport Advice wdj03 Roofing/Siding 7 10-06-2006 04:59 PM
