My Push Mower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 05:03 PM   #1
my push mower
why is my push mower cutting off after running for 10 minutes
hermanbandit is offline   Reply With Quote
Old 05-07-2011, 05:13 PM   #2
Everytime i cut grass my push mower cut off after running for 10 minutes ,why is this happening ?
Old 05-07-2011, 05:38 PM   #3
bubbler's Avatar
Rewards Points: 256
Does it cut out suddenly, or seem like it's stalling out?
Could be a bad gas cap vent--try running w/ the cap put on very loosely... if it stops happening, by a new cap
Could be a loose wire that only making contact after what seems like ~10 mins, but sounds unlikely.
My vote is a fuel issue.
bubbler is offline   Reply With Quote
Old 05-07-2011, 05:53 PM   #4
NACE Coating Inspector
mustangmike3789's Avatar
dirty air filter, condensor, sparkplug, coil. i would start with the plug and clean the filter. plugs will break down as they get hot. probably 9 out of 10 times small enging problems can be traced to the sparkplug.
mustangmike3789 is offline   Reply With Quote
Old 05-08-2011, 07:45 PM   #5
biggles's Avatar
drop the float canister and check that bolt you have just removed there is a little hole in it(on the threads) that the gas goes up into the engine piece of grass might be in it should be able to blow thru it
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 05:42 PM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 11:52 AM
My push lawn mower cuts out. Tommy Gunn Tools 2 05-05-2010 08:51 PM
Looking for a new Push mower for residential mowing speedster1 Landscaping & Lawn Care 9 04-02-2010 05:12 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
