My Lawnmower Won't Start. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 06:20 PM   #1
Rewards Points: 150
My lawnmower won't start.
This is a one year old Husqvarna riding mower 20hp Kohler engine and I'm getting fire to the sparkplug and gas to the carb, has a clean air filter. I dropped the carb bowl down, and gas will flow through. At the bottom of the bowl is a small push plunger with a red wire going to it. How does this electrical fitting with a plunger allow gas or no gas?
bernieb is offline   Reply With Quote
Old 04-07-2011, 06:28 PM   #2
Been at it for 45 years
This Old Spouse's Avatar
Rewards Points: 79
By any chance did you drain out the old gas and replace with fresh?
This Old Spouse is offline   Reply With Quote
Old 04-07-2011, 08:59 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Beat me to it!
XXX
Old 04-08-2011, 05:57 AM   #4
Rewards Points: 150
I confess, I am using last years gas, but there's something else in the works here. I can take a spray bottle and give the carb a shot of gas and it'll fire up for a couple of seconds. I've used carb cleaner and not a pop, so today I'm taking the carb bowl off and watch the plunger/electric item when I hit the key. And I'll use fresh gas !
Old 04-08-2011, 01:29 PM   #5
Rewards Points: 150
For what its worth, the mower is now working. I dropped the carb bowl down and exposed the plunger electric gizmo, or whichmacallit,and turned the ignition key to start and the plunger did nothing,so I seated the plunger and put everything back together.........mower started, replaced nothing. I'm guessing that this electric activated plunger shuts off the gas inside the carb due to a malfunction. (Still used old gas)......sure would like to know the sequence of operation of the gizmo.
Old 04-08-2011, 06:56 PM   #6
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
there is so much alcohol in gasoline anymore that it really messes with the rubber in a small engine. I use to rebuld them when they got sticky like that but the last couple I have just ordered new carbs online. a few bolts and you up and running.
danrb007 is offline   Reply With Quote
Old 04-13-2011, 06:31 AM   #7
Rewards Points: 150
The mower quit again, and found a local parts place that had the "Qizmo" in stock, which she called a fuel pump, but on the package was called a "solenoid repair kit" which replaces kohler 12 -757-33-s
ch/cv11-16 ....65 bucks ..ouch.....back to mowing .
my lawnmower will only start crossing wires marcus oshea Landscaping & Lawn Care 4 06-21-2010 07:43 AM
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Murrary Riding Lawnmower Won't Start lerxstrulz Landscaping & Lawn Care 14 05-08-2010 11:27 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
