My Lawnmower Will Only Start Crossing Wires - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 08:50 AM   #1
my lawnmower will only start crossing wires
is it the solonide that needs replacing it was all working fine until i turned it on its side and had an oil leak i cleaned this up had a bit of clicking then nothing only way to start is crossing wires then it runs smoothly? thanks for the help
marcus oshea is offline   Reply With Quote
Old 06-20-2010, 09:57 AM   #2
Household Handyman
Rewards Points: 1,408
Need more info here: What type of mower (push-riding), what wires are you crossing?
Old 06-20-2010, 12:08 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
careful crossing wires you could burn out an ignition module in a heart beat
Tom Struble is offline   Reply With Quote
Old 06-20-2010, 05:00 PM   #4
its a ride on mower 13.5 hp i'm crossing the battery wire to start it
Old 06-21-2010, 08:43 AM   #5
Household Handyman
"i'm crossing the battery wire to start it" I'd still like more info here but- -I'm guessing you are "jumping" the battery from another battery to crank the mower. If you are jumping the battery and getting the mower to crank, you solved your own problem. You stated that you turned the mower on it's side, for some reason. Was the battery still in it when you turned it on it's side? IF SO--you probably ruined the battery. A lead/acid battery will build up "sulfates" as it is used over any period of time, from one hour to one year. Once you turn the battery on it's side the sulfate's will release from the plates and short out the other plates=dead battery, that's why the solenoid was clicking. So-if you are jumping the battery, and the mower cranks and runs, you need a new battery. Hopefully that is all you will need. David
The Following User Says Thank You to Thurman For This Useful Post:
marcus oshea (06-21-2010)
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 12:31 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
