My First Sodding Job, A Few Questions I Have... - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 10:01 PM   #1
My first sodding job, a few questions I have...
Tomorrow is I plan to lay sod for the first time. I just moved our shed back about 25 ft and plan to sod the area where the shed was and the area that was in back of the shed. (now in the front of the shed). The area is about 400 sq ft...
The area under the shed was a sand\clay mixture and the other areas were tilled and seeded last year. I have since dumped about 2 cubic yards of new topsoil and graded the area to the best of my ability. I want make sure that the area is compact as possible. I assume the only way to do this is by rolling the area. Can you rent a roller from HD? Has anyone ever done this...
Next question is in relation to sod types... I live in Central NJ, and one of the reason I am sodding is due to how late in the season I am, seeding could be questionable at this point. I think I have enough time for sod to take, is that correct? Suppose to be mid seventies tomorrow.
I had redone the whole front lawn last year, tilled the whole lawn and dropped about 12 cubic yards of topsoil. I then seeded and it came it great this year. The area I am doing tomorrow and the existing lawn will "butt" up...
What kind of sod, I used johnthan green sun shade for the front and would like a sod that will blend in well with that... Any ideas?
Also, I guess before I lay down the sod, I will roll out the new topsoil, should I add lyme and starter fertilizer?
Next where I plan to butt up the new with the old, should I just use a straight shovel and create a 1/2" starting line? how do people in the business handle this?
BTW: what should I expect to pay for 500 sq ft of sod?
Thanks -- WorkOnIt...
I will post pics when I am completed
WorkOnIt is offline   Reply With Quote
Old 10-13-2008, 06:08 PM   #2
Don't know it all, yet!
Nah! Perfect weather for reseeding. Shouldn't be any trouble keeping this small area watered for 2 weeks.
Don't know about lime in your area. Light amount of high P fertilizer (the middle number). 18-24-12 would work, as would 0-15-0. Not familiar with this variety of grass, is it fescue, bluegrass, etc? If it's a cool weather grass, I would put a little N in there.
Roots continue to grow until SOIL temp reaches about 50* F. You have plenty of time now for the seed to germinate, get a good root system established without the stress of the heat of summer.
I put out some rye a couple of weeks ago and it was up in five days.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-20-2008, 09:36 PM   #3
sod
So, how did this turn out? Hopefully you've been watering! We were going to reseed and have now run out of time. Oh, well!
Allison1888 is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Hey gang, another Neewb here! 261,483 questions to follow! Portlandkids Flooring 6 08-30-2008 09:34 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
