Mushroom Problems - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 09:36 AM   #1
Mushroom problems
Hi, I layed new sod from Home Depot in my front lawn about a month and a half ago. Just about a couple weeks ago I've noticed these little things coming out of the grass, yep mushrooms. I definelity do not like the site of them in my lawn, and they are little sprouting in several spots. And lately we've been getting a lot of rain, so no need for me to water. I would like to know is there a way to completely get rid of these things. Are fungicides good? And should I remove the mulch in the yard as well?
mzchokolit is offline   Reply With Quote
Old 06-21-2009, 09:03 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
did you lay the sod over an old mulch bed? Mushrooms are the "fruit" of fungi, that needs organic material, like decaying mulch or a rooting stump, to thrive. i doubt the mushrooms are from the sod, but more likely grew from a combination of what's under the sod, combined with the extra water they are probably getting from your efforts to help the sod take root
Mr Chips is offline   Reply With Quote
Old 06-22-2009, 07:04 AM   #3
ccarlisle's Avatar
Not sure it matters where they came from, but the above poster is right...I've alwyas found that fungal infestations are of short duration and that to eradiacate them involves changing the pH of the soil.
Fungi are very fussy about what acidity level exists in the soil they stand in and therefore by changing the pH you change everything for them. Now depends on what pH you already have - but since soil should be slightly acidic anyway, try watering them with a weak vinegar solution.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 06-23-2009, 09:25 AM   #4
Thanks for the replies. No, I didnt lay the sod over an existing mulch bed, just added a little mulch to the lawn around it. But I probably should've turned the grass over better. I did cut a few bushed down though and maybe the dead roots underneath may be helping them. But I did notice since we've been having 90 degree days and no water, looks like they've disappeared, maybe for a second. Maybe I will try the vinegar or baking soda solution first if I see anymore. As far as getting the pH of the soil, how do I determine that? Im really not a gardener, but just trying to make things look better around the house. Thanks
Old 06-23-2009, 12:51 PM   #5
What state are you from? I'm on the shores of Lake Michigan and we have had the wettest spring that I can remember, here, seems everybody has mushrooms in the lawn, even in my sandy soil that gets sun all day. In my case I know it will pass once it starts to dry out.
Rumpole is offline   Reply With Quote
Old 06-26-2009, 04:36 PM   #6
Smile
Im from Illinois, Chicago. And out of all the years we had sod on another property I've never seen mushrooms. Crazy, but its a first time for everything. Haven't saw them in a week because it's been hot and dry. Hopefully they stay away.
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
phone problems AStott Electrical 13 06-07-2008 06:27 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
