Murray Yard Tractor Won't Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 10:08 PM   #1
Murray yard tractor won't start
10 year old Murray 17HP 46". New Battery. Engine won't turn over. Any ideas?
pplant is offline   Reply With Quote
Old 07-18-2008, 10:14 PM   #2
Did you check for blown fuses?
Is it out of gear?
Did you check all the safety switches? (under the seat, netural, blade out of drive...)
redline is offline   Reply With Quote
Old 07-19-2008, 10:11 AM   #3
Whatamess
Check the solenoid if the mount is broken it is not grounded.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-19-2008, 10:20 AM   #4
Check battery voltage at the posts with a test light or voltmeter.
If the light goes out when attempting to crank it is a bad battery or it's low on charge.
If the light dims slightly it is the current draw from the solenoid but the starter motor is not drawing current which means the internal solenoid contacts are worn out.
If the light doesn't dim at all, clean the posts/terminals with sandpaper.
Mower won't start, anything I can try before bringing it to the shop? joeyboy Landscaping & Lawn Care 6 08-05-2008 03:08 PM
My yard is ugly and I don't know an easy way to fix it. keyser soze Landscaping & Lawn Care 22 07-05-2008 03:43 PM
New Yard SnowUtopia Landscaping & Lawn Care 3 03-23-2008 10:46 PM
Remulching my yard is NOT an option, other suggestions? PICS J187 Landscaping & Lawn Care 20 05-27-2007 02:05 AM
