Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-14-2011, 09:18 PM   #1
Question
Murray riding mower wont start again
We have a bit of a puzzle here.
It starts with a 12.5 HP 40” Murray riding mower that sat unused for about 3-years under shelter.
I re-charged the old battery and it started the first time after draining the old gas from the fuel line at the carburetor, re-filling the gas tank with new gas and adding a squirt of starting fluid on the air filter. Some sneezing at first that settled down after a few moments, so I engaged the blades and ran it around for a few minutes. I heard some clattering from the blades hitting the metal safety cover, so I shut it down and bent the metal under the cover to stop that.
Now comes the puzzle. It won’t restart. Nothing. Not even a click from the solenoid being engaged if that were to happen like with larger engine automobiles.
Since it seems electrical, I have replaced the ignition switch, the solenoid, the battery, and the 15A fuse. Still nothing. I even tried to bypass the seat safety switch thinking that was causing a break. Nothing.
Before I get a meter and try to track the cause step-by-step from a rough electrical diagram, I want to toss this out for your feedback. The cause could be something obvious to one of you and overlooked by me. I welcome your feedback. Thanks much!
ezthinkr is offline   Reply With Quote
Old 05-14-2011, 09:50 PM   #2
just a tool guy
mickey cassiba's Avatar
Prolly a dumb question...but did you check the oil level?
Oil level switch in most of 'em these days...
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 05-14-2011, 11:46 PM   #3
also do you have the blades engauged when you are trying to start it?
bluebird5 is offline   Reply With Quote
Old 05-15-2011, 11:15 AM   #4
remove you plug wire and try to turn the engine over by hand. if you can remove the spark plug, cover the plug hole with you thumb or a fat finger, turn the engine over and check for cylinder suction, unless you have a pressure guage. hopefully you didn't cause engine damage.
Otherbill is offline   Reply With Quote
Need Electrical HELP for riding mower RiceTruck Electrical 3 10-19-2010 04:24 PM
My riding mower BABYGIRL44 Electrical 4 06-06-2010 11:24 AM
Murrary Riding Lawnmower Won't Start lerxstrulz Landscaping & Lawn Care 14 05-08-2010 12:27 PM
Ariens or Craftsman Riding Mower? Osiris Landscaping & Lawn Care 3 04-20-2010 09:46 PM
Murray riding mower Help popcorc Landscaping & Lawn Care 0 01-26-2010 06:43 PM
