murray riding mower wont start
Hi all, I need some advice,
My mother has a murray riding mower I am trying to get running so I can cut her grass. She has a Murray 12.5hp riding mower that has been sitting for a couple years. It ran fine when she put it away. I pulled it out and it was dead. Here is what I did; - Put in a new battery - Put in a new spark plug - Changed Air filter - Changed fuel filter - cleaned the battery connectors The motor acts like it wants to turn over but it won't go all the way. Does it need to be primed somehow? I have no idea how to take a motor apart unless I have a diagram. I am not a mechanic by any means, so any input would be greatly appreciated. thanks. |
Things you haven't mentioned:
Clean all of the battery and starter terminals. Install new gasoline. Varify the choke is working properly. Check for air-lock in fuel line. Be sure battery is fully charged.:) |
- I bought a brand new battery from the store, I assumed it was charged. I don't know how to check the charge on a battery. The terminals were spotless. - I did drain the old gas and use new. - I don't know how to check the choke. When it was engaged it was pushing something on what I think is the carburetor forward. (I watched what it was doing with the engine cover off when I was pushing the lever/choke up and back) - I don't know what an air-lock in the fuel line is. |
You may still have bad gas in the fuel line and the float bowl. Not something I'm comfortable giving instructions on if you're not familiar with the process.
I got some starter fluid and put it in the carburetor. it started and ran for a couple of seconds.
I pinched the fuel line with some pliers and took the bowl off and cleaned it with carb cleaner. it was nasty. It had a thick orangy coating in it. Based on that I assume the whole carburetor needs to be cleaned? Possibly new fuel lines? |
Sounds like the carb needs to be cleaned.
My thought was the valve might be stuck but you got it to turn over. I would still be inclined to spray a LITLE WD 40 down the shaft where the spark plug sits. By the way, ethanol mixes in fuels might be great for the environment and run in cars but they are killer for small engines. Make sure the spark plug is gapped correctly. If it is off, you are going to get limited combustion. Have you actually pulled the gas tank and cleaned it? |
You should try a John Deere mower. They seem to always start for me after sitting for a long time unused.
http://www.homeproductsunlimited.com |
There are two cut off switches maybe a third
Cut off switches
I found 2 one under the seat of the Murray 495103 model that is grey and another on the side by the lever to start the blades, this one is hard to disconnect, I had to disconnect this from its place, then hold the button down while turning the engine over, this workes fine, the one behind the seat I disconnected one of the yellow wires, It ran fine now, for a while, the engine has stopped, and will try and clean the carburator, I replaced the cellenoid, starter and the one in the little panel area in front of the seat but hat is not the problem, I update on the carburator project, it seems to flood in the air filter chamber, does any one have any advice ? Or does anyone know of a third cut off switch? thank you Susan |
| All times are GMT -4. The time now is 06:15 PM. |
