Mudjacking - Mud Or Concrete Slurry? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 01:06 PM   #1
mudjacking - mud or concrete slurry?
Have been receiving quotes for mudjacking work consisting of raising to proper pitch several sections of sidewalk, and two patio slabs. Most contractors have quoted as mudjacking with concrete slurry (3.5 bag mix if I recall). Latest quote received was for mudjacking using mud. This company indicated concrete slurry use was inferior to mud due to "pillaring". Any opinions on method or other input is appreciated
thanks
-Frank Rizzo
rizzo is offline   Reply With Quote
Old 06-16-2009, 02:42 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If you mean mud as in dirt mixed with water, then that is incorrect. As the water leeches out of it, it would shrink and allow the slab to settle. It is done in this area with a somewhat soupy mortar mix. Almost like grout. Guys call it mud, but it won't shrink as it cures.
Old 06-16-2009, 03:15 PM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
2 guys, a self propelled grout pump, and a Hilti did my front and back walk (80 linear feet) in under 2 hours. A local outfit (next town over) charged me $350 (2005), and I thought it was worth it. More cost effective than doing new slabs, that's for sure. Came out great. Their grout mix was the consistency of pancake batter. Regular grout mix. They patched the holes with concrete patch mix.
Aggie67 is offline   Reply With Quote
Old 06-16-2009, 09:55 PM   #4
Thanks for the response. Good to know what is commonly used for sub-slab injection. We'll finish up the quote process and proceed.
Old 08-31-2012, 03:23 PM   #5
I have a tunnel under the concrete driveway the tunnel is about 8 inches in diameter and 25 ft long open at both ends and level.I was advised by a builder to mix cement with water liquid as milk and pour it in-no need for a pump. The hole is level essentially,I want the mixture to harden so that the concrete is supported properly.I contacted a contractor who responded the job was too small-get a local handyman.I am not opposed to buying a manual grout pump/hose and filling it my self.Im just trying to do it as low cost as possible,but have no voids. If you all think the grout pump is the way to go,what kind of mixture should I buy? I live above snow line. Thank you.
Rmankty is offline   Reply With Quote
Old 09-01-2012, 08:44 PM   #6
Rewards Points: 3,724
Cheapest manual grout pump with hose i know of is $1300.00,and the self propelled one the previous poster mentioned start at about $5000.00.
Canarywood1 is offline   Reply With Quote
Old 09-02-2012, 06:09 AM   #7
Thanks for the information.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
