MTD Yard Machine Lawn Mower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 08:55 AM   #1
MTD yard machine lawn mower
I can't get it to start. The carborator isn't getting fuel. I replaced the fuel line and filter and the solenoid on the bottom of the carb. It will start if a put a few drops of fuel into the carb.
qrilty is offline   Reply With Quote
Old 05-11-2011, 09:17 AM   #2
Framing Contractor
Rewards Points: 120
Make sure the choke is not stuck. Sometimes debris can get in there and the linkage will get stuck.
sixeightten is offline   Reply With Quote
Old 05-11-2011, 09:53 AM   #3
A Little Of Everything
Rewards Points: 1,364
So you're not getting gas TO the carb, or not getting gas THROUGH the carb?
If you're not getting gas TO the carb, it should be pretty easy to diagnose & fix.
If you ARE getting gas to the carb, there's a good chance you've got dirt in the bottom of the bowl, and it is plugging your jet. The fix for that is also relatively simple.
DrHicks is offline   Reply With Quote
Old 05-11-2011, 05:52 PM   #4
Rewards Points: 150
That solenoid that is in the bottom of the carb bowl, can you see the plunger going back and forth while cranking with the bowl down? I think this solenoid is a fuel pump, but not sure. I had a similar problem and replacing the "pump" cured it.
bernieb is offline   Reply With Quote
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
lawn mower small engine...struggling joetab24 Automotive Repairs 1 05-05-2010 08:00 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 01:22 PM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 02:37 PM
